Question: Multiple subroutine with for-do loops
I am trying to write a program that contains multiple subroutine calls. I understand the placement of the single for-do loop to call the "lowest value" subroutine.
Here is program.
main := proc( x :: Vector)
   local n, k, y, value_min, index_min;
   n := LinearAlgebra[Dimension](x);
   y := x[1..n];
   for k from 1 to n-1 do
      value_min, index_min := lowestValue(y,k,n);
      y[index_min] := y[k]; y[k] := value_min;
   return y;
lowestValue := proc( y :: Vector,k :: integer,n :: integer)
   local value_min, index_min, j;
   index_min, value_min := k, y[k];
   for j from k+1 to n do
      if evalf(value_min) > evalf(y[j]) then
         index_min, value_min := j, y[j];
      end if;
   return value_min, index_min;
I also need to do this subroutine within main program
highestValue := proc(s)
   local i, n, value_max, index_max;
   n := LinearAlgebra[Dimension](s);
   value_max := evalf(s[1]);
   index_max := 1;
   for i from 2 to n do
      if evalf(s[i]) > value_max then
         value_max := s[i];
         index_max := i;
      end if;
   return value_max, index_max;
