Question: Java Error
Hello I have a problem with running Maple 12. Every time i try to run it i get the java virtual machine error. This must happen to alot of other people too because i did some looking around to find a solution. I found some solutions, like delete the # in front of maxheap=700m or lower the maxheap to maxheap=650m in launch.ini in the bin.win in the Maple file. All goes swell until i try to save the correction (im doing this all in notepad) and i get the message that it can't save and to make sure that the file and path are correct. This makes no sense because i am saving it in the same spot as and .ini file. Please Help!!! Thanks
