Question: Procedure/Module description
I write a lot of maple code that my advisor uses, and I'm wanting to make it easier for him to use with as little extra work on my side as possible. Most recently I've started using modules to hold the procedures that go together. For example, I may have something like this
Resultants := module()
  description "This uses various methods to find resultants.":
  export UResultant, MacaulayResultant:
  MacaulayResultant := proc(F,vars)
    -- description and code
  UResultant := proc(F, vars)
 --description and code
end module:
print("Resultants"):
print(op([1,1], Resultants)):
This way whenever my advisor includes the file I send him ("resultants.maple") it tells him the name of the module and the names of the exported procedures from the module. Then he can type Describe(Resultants:-UResultant): to get the parameter list and the description, or just Describe(Resultants) to get everything. My only problem is that I can't seem to figure out how to get the description lines to not be ugly, when they are long. I've found the following options work (but are ugly):
description "One big long line of description that is annoying to view in any editor, esp. vi because wrapping is just plain ugly to me":
description "The first line goes here",
  "then there is a second line",
  "and so on.",
  "call me lazy but there are too many \"'s and it's still ugly to me":
description "
  Alternatively I can just totally ignore closing
  the string until the very end. This has the
  problem of reporting a warning for each procedure
  or module that contains it.":
So anyway, are there any other ideas to how I can construct my description with the least headache and still looking pretty?
Thanks, Korben
