Question: Bug?
Question:Bug?
Futbolista 28 Maple
Dear all,
In the attached file there seems to be a little calculation bug.
Simply let the file run through. In the fourth line from the bottom CSBt equals a number greater than zero. I copied the same expression in the file's very last line. There the result of CSBt is zero.
The identical expression gives two different results. The "correct" result is zero.
It seems to me that the file is somehow damaged. Has this happened to anyone before and what can you do about it?
Many thanks for your help!!
Florian
View 5919_other dur + cons_num_B_1.mw on MapleNet or Download 5919_other dur + cons_num_B_1.mw
View file details
