Question: printing variable values on an animation
I'm currently outputting some animations, but I'm not using the animate command - I'm using the command display([seq(tmp_alpha_plot||kk,kk=1..nt)],insequence=true) having previously created tmp_alpha_plot||ii:=display([ plot([seq([r_arr[i],alpha1_arr[i,ii]],i=0..nr)]), plot([seq([r_arr [i],alpha2_arr[i,ii]],i=0..nr)], color=magenta)]): What would be useful for diagnostics purposes is to be able to print in the corner of the animation both the timestep/frame currently displayed (I know this is automatic when you use the animate command, and I'll change if I need to), and the actual numerical value of the variables alpha1_arr and alpha2_arr. It would also be useful if I could also show the numerical values of some other variables I'm working with, as they're defined at that time. I can't seem to find what I need in the maple 10 help files - any suggestions would be greatly appreciated! Thanks, Rebecca.
