Question: Code Generation
Question:Code Generation
hpina 8 Maple
I am using Maple 10 to generate via codegen and CodeGeneration systems of ODEs to be externally solved by CVODE (a solver written in C). It happens that the lines so generated are so huge that the C compiler chokes. Searching this forum for previous posts I found the recommendation to use the optimize option in order to break long lines. However this seems to be insufficient and I wonder if there is a simpler solution like specifying the maximum line length and have Maple handle the breaking.
TIA,
Heitor Pina
