Question: How to define a boolean function?
I´d like to use the remove command, to select elements of a list.
E.g.
L:=[1,2,3,4,5,6,7,3,9];
L1:=remove('boolean function',L);
Where can I get an overwiew of all boolean functions, i.e. commands, that output true, false or fail?
E.g. I wanted to simply say
L1:=remove(<>3,L);
which should just leave all "3" values in L1, but that didn´t work. So I needed to define a boolean function to say "if element of List L is not 3, then remove it"...
Where can I view all permitted commands for that first argument of remove, or select?
