Question: simple procedure won't work... not sure why
Below is a small tidbit of code that operates on the matrix vel and updates its values.  When I check the values of the indices in the matrix, every single element, barring vel(1,1), vel(1,2), and vel(1,3), is equal to 0.
vel := Matrix(3, 241, datatype = float[8]);
step := 0.1;
vel(1, 1) := 5; vel(2, 1) := 95; vel(3, 1) := 3;
UpdateAllVelocities := proc (i, vel::Matrix, accel::Matrix, step);
#I understand these calls are quite pointless... I only set every single element of the matrix equal to the first elements in an attempt to isolate the cause of my runtime error.
vel(1, i) := vel(1, 1);
vel(2, i) := vel(2, 1);
vel(3, i) := vel(3, 1);
for i from 1 to 241 do
UpdateAllVelocities(i, vel, accel, step);
Does anyone see what simple mistake is causing this problem?
Thank you in advance.
