Question: differential equation with two solutions
restart:
ode:=k_m*diff(T(x),x,x)+cp*m_v*diff(T(x),x)=0;
ics:=D(T)(0)=-q/k_m,T(L)=TV;
dsolve({ode,ics});
(3)
simplify(%, trig):
  combine(%, exp) assuming S::real:
  collect(%,q):collect(%,cp):collect(%,m_v):        simplify(%, size) assuming S::real;
(4)
 If I change just only one sign from positive to negative in the above solution (4) which will now take the following form
T(x):= TV-(-exp(-cp*m_v/k_m*L)+exp(-cp*m_v/k_m*x))*q/cp/m_v;
(5)
I have checked it that both the soltuions satisfy the differential equation. Now my question is, can the second solution (5) in which I have only change one sign from positive to negitive is correct?
If both the solution are correct then what is the best way to get more solutions of a differential equation of there is more then one solution.
Download section.mws
