Question: Error message when trying to plot graph
Hi!
I'm sure there is a simple solution to my problem, but because I'm fairly new to using Maple, I can't figure out why my graph won't work. All I'm trying to do is graph a function along with its first and second derivatives within the same graph. The original function is f(x)= (2+sinx)^x2/(x2+1).
I defined the function as f and then found the first derivative by using df:=D(f);. The second derivative I used d2f:D=(df);. Both derivative calculations came out just fine.
Then when I went to graph all 3, this is what I put:
plot({f,df,d2f}, -10..10);
And it gave me the error message of:
Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct.
Any ideas on how to fix this? Any help is greatly appreciated, it's for a class assignment.
-Kyu
<math xmlns='http://www.w3.org/1998/Math/MathML'><mrow><mi>df</mi><mo>&coloneq;</mo><mi mathvariant='normal'>D</mi><mfenced open='(' close=')' separators=','><mrow><mi>f</mi></mrow></mfenced><mo>&#x3b;</mo></mrow></math>
