Question: Hydraulic Simulation failed
Hello Samir,
Could you explain me what this circuit couldn't be simulated if I replace the default fluid properties to the water's ones? The default fluid is an hydraulic oil, but for water (density = 998 kg/m^3, bulk coefficient = 2.2 10^9 Pa and cinematic viscosity = 10^-6 m^2/s) the simulation gives unsuccessful results. I tried with several solver with similar results.
Moreover, similar behaviours I experimented if I include chamber components into the hydraulic circuits.
Thank you for your coments.
Best regards,
Gustavo
