20 years, 301 days
@Robert Israel 10^6 Gracias.
How to develop fourth-order differentiation matrix?
From the attached document above is not clear to me.
Gracais
Gracais
See this example peak_det_in_functio.zip
I hope it helps.
I want to play in Maple the examples shown here:The Derivation of Second and Fourth Order Differentiation Matrices.
presentation.pdf
plot([y,sol2,sol3],x=0..10,color=[red,blue,green]); # All very close to lying on top of each other.
eval(sol1,x=4.5)-eval(sol2,x=4.5);
-.527680706221360
eval(sol1, x = 4.5)-(eval(sol3, x = 4.5))
-.527681123666859
eval(sol2, x = 4.5)-(eval(sol3, x = 4.5))
-4.17445499500957*10^(-7)
-.527680706221360
-.527681123666859
In all good examples, fast and low resource consumption, which can be seen in the Forum, there is a need to expiate the internal sequence called the command to obtain these results. Using showstat (...). Is this view correct?
Drive, use "internal code" is needed expertise and time in the use of maple. Also found little or no information in support of maple about it.
HerClau
HerClau
My apologies. This was a mistake I made by copying the code in the forum.
 Example_1__FFT_of_a_.mw
P := proc (x, lambda) piecewise(x < 0, 0, lambda^x*exp(-lambda)/factorial(x)) end proc:
Lu := proc (a) sum(P(x, lambda), x = 0 .. a)-0.5e-1 end proc:
Ll := proc (a) sum(P(x, lambda), x = a .. infinity)-0.5e-1 end proc:
fsolve~(Lu~(<0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10>), lambda, 0 .. 20):
fsolve~(Ll~(<0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10>), lambda, 0 .. 12):
Perfect.
How to achieve these results using the Statistics Package?
How to plot the confidence limit ?
Perfect.
What can I do to achieve display help?
@pagan Thanks for the suggestion
Please run the link
The image that I hope, as the book, for the TM matrix is:
Matrix TM:
Please run the link
Matrix TM:
First 7 8 9 10 11 12 13 Page 9 of 13
