20 years, 301 days
@mois
sol := Search(ObjFn, [op(ModCons), op(Bounds)], startpoint, variables = var, tolerances = 10^(-8), checkexit = 10, evaluationlimit = 10000, step = 0.1e-3, maximize)
Error, (in LinearAlgebra:-VectorNorm) object too large
sol := Search(ObjFn, [op(ModCons), op(Bounds)], startpoint, variables = var, tolerances = 10^(-8), checkexit = 10, step = 0.1e-3, maximize)
Error, (in is/internal) object too large
 sol := Search(ObjFn, [op(ModCons), op(Bounds)], startpoint, variables = var, tolerances = 10^(-8), checkexit = 10, step = 0.1e-1, maximize);
sol_2 := Search(ObjFn, [op(ModCons), op(Bounds)], startpoint, variables = var, tolerances = 10^(-8), checkexit = 10, evaluationlimit = 5000000, maximize, penaltymethod = true)
Error, (in evalf/piecewise) object too large
Please be that exemplifies the use of options evaluationlimit, step, penaltymethod, using maple_WorkSheet
http://www.mapleprimes.com/view.aspx?sf=130474/430212/DirectSearch_Alkylat.zip
@mois  My question is how to determine the mean values, by default, have the step and limit evaluation?
@mois How to increase the limit evaluation?
If I increase a lot the evaluation limit, I move away from the result.
There is a compromise between criterion of evaluation limit and the step?
How slow the step?
I received the following alert:
“Warning, cannot find feasible initial direction of search;specify a new initial point, decrease step or repeat search”
How slow the step?
I get the error:
> earthquakedatasave();
Error, (in HTTP:-Get) cannot establish TCP connection to `earthquake.usgs.gov' at port 80
How to implement this Warning from "DirectSearch"?
Warning:
Warning, limiting number of function evaluations (10000) is reached; set initial point equal to extremum point obtained, increase evaluationlimit option and continue search
How to increase the evaluationlimit option?
Warning:
Please help me. For more than read the help and test different configurations will goal fail. Alkylation_Process_M.zip
http://www.mapleprimes.com/view.aspx?sf=129808/428978/Alkylation_Process_M.zip
LocalSoln := GlobalSolve(ObjFn, ModCons, op(Bounds), initialpoint = {InitValues}, method = reducedgradient, maximize)
[1.61589218620872277, [AlkylYld = 3.19860167415445850, Octane = .946426422111240396, Ratio = 9.35681824212461776, AlkErr = 1.01010099999999992, F4Err = .995316746937184748, F4Perf = 1.51638086164843111, AcidDilut = 1.99970064669291458, OctErr = .989999999999999990, AcidErr = 1.07833383710255636, IsobutRec = 1.50517360863708549, OlefinFeed = 1.83010164762507355, IsobutMak = 2.07219239506969810, AcidFeed = .742637470146617296, AcidStren = .902287112879196718]]
Search(ObjFn, ModCons, pointrange = Bounds, startpoint, variables = [Octane, AcidFeed, AlkylYld, IsobutMak, IsobutRec, OlefinFeed])
Error, invalid input: too many and/or wrong type of arguments passed to DirectSearch:-Search; first unused argument is pointrange = [IsobutRec = 1.0 .. 1.6, OlefinFeed = 1.0 .. 2.0, IsobutMak = 1.0 .. 2.5, AcidFeed = 0. .. 1.2, AlkylYld = 2.0 .. 4.0, AcidStren = .85 .. .93, Octane = .9 .. 1.0, Ratio = 8.0 .. 12.0, AcidDilut = 1.2 .. 2.0, F4Perf = 1.45 .. 1.62, AlkErr = .99 .. 1.010101, OctErr = .99 .. 1.010101, AcidErr = .90 .. 1.111111, F4Err = .99 .. 1.010101]
GlobalSoln := GlobalSolve(ObjFn, ModCons, op(Bounds), initialpoint = {InitValues}, maximize)
[1.78395933308714306, [AlkylYld = 3.07007225990883326, Octane = .955298465585722844, Ratio = 9.91806452479753808, AlkErr = 1.01010099999999992, F4Err = .989999999999999990, F4Perf = 1.55140949167390718, AcidDilut = 1.24674177887431914, OctErr = .989999999999999990, AcidErr = 1.10584991070415373, IsobutRec = 1.54173739656644204, OlefinFeed = 1.75515193917180490, IsobutMak = 1.99033621813427252, AcidFeed = .619799622265214788, AcidStren = .922999919802020341]]
GlobalOptima(ObjFn, ModCons, pointrange = Bounds, startpoint, variables = [Octane, AcidFeed, AlkylYld, IsobutMak, IsobutRec, OlefinFeed], maximize)
Error, invalid input: too many and/or wrong type of arguments passed to DirectSearch:-GlobalOptima; first unused argument is initialpoint = [IsobutRec = 1.5, OlefinFeed = 1.7, IsobutMak = 1.9, AcidFeed = .5, AlkylYld = 3.0, AcidStren = .9, Octane = .95, Ratio = 10.0, AcidDilut = 1.5, F4Perf = 1.55, AlkErr = 1.0, OctErr = 1.0, AcidErr = 1.0, F4Err = 1.0]
How to proceed with DirectSearch v2?
> GlobalSearch(TF, {B >= 0, 0 <= G, 0 <= a, B <= 1, G <= 1, a <= 1}, initialpoints = [G = .1], variables = [a, B, G], maximize, evaluationlimit = 5000, solutions = 1), time();
Error, invalid input: DirectSearch:-GlobalSearch expects value for keyword parameter initialpoints to be of type {Matrix, list(Array), list(Vector), list(list)}, but received [G = .1]
> GlobalSearch(eval(TF, G = .15), {B >= 0, 0 <= G, 0 <= a, B <= 1, G <= 1, a <= 1}, maximize);
Error, (in DirectSearch:-Search) cannot find feasible initial point; specify a new one
@alex_01
con1 := add(W[i], i = 1 .. nstock) con2 := seq(W[i] con3 := seq(W[i] >= 0, i = 1 .. nstock):
does not work. I do not understand the syntax
@alex_01
@Markiyan Hirnyk
I prefer a worksheet with a StartUp code.
10^6 Gracias
@Markiyan Hirnyk
10^6 Gracias
5 6 7 8 9 10 11 Page 7 of 13
