20 years, 301 days
taken from solution in use in  Dsolve2
eval(%,applyop~(apply,1,dat[2],t));
@Preben Alsholm
eval(%,dat[2]) is not entirely satisfactory, as shown in the highlighted characters in bold
 deq := diff(y(t), t$2) = y(t)-x(t), diff(x(t), t) = x(t);
init := y(0) = 1, D(y)(0) = 2, x(0) = 3:
dat:=DEtools[convertsys]({deq}, {}, {x(t), y(t)}, t,Y,YP);
dat := [[YP[1] = Y[1], YP[2] = Y[3], YP[3] = Y[2]-Y[1]], [Y[1] = x(t), Y[2] = y(t), Y[3] = diff(y(t), t)], undefined, []]
eq:=Dsolve(dat);
dsolve(eq);
eval(%,dat[2]);
{diff((y(t))(t), t) = -exp(-t)*_C2+exp(t)*_C1-(1/4)*_C3*exp(t)-(1/2)*_C3*t*exp(t), (x(t))(t) = _C3*exp(t), (y(t))(t) = exp(-t)*_C2+exp(t)*_C1+(1/4)*_C3*exp(t)-(1/2)*_C3*t*exp(t)}
remove(has,%,diff);
{(x(t))(t) = _C3*exp(t), (y(t))(t) = exp(-t)*_C2+exp(t)*_C1+(1/4)*_C3*exp(t)-(1/2)*_C3*t*exp(t)}
#Comparison:
dsolve({deq});
{x(t) = _C3*exp(t), y(t) = exp(-t)*_C2+exp(t)*_C1+(1/4)*_C3*exp(t)-(1/2)*_C3*t*exp(t)}
@Preben Alsholm
eq:=Dsolve(dat);
dsolve(eq);
eval(%,dat[2]);
remove(has,%,diff);
#Comparison:
dsolve({deq});
Dsolve2:=proc (eqs::{list,set}(equation),ics::{list,set}(equation),vars::{set,list}(function(name)))
local t,dat,A,b,v,vi,ic,Xt,X,x,sys;
uses LinearAlgebra;
t:=op(op~(vars));
dat:=DEtools[convertsys](eqs,ics,vars,t,x);
A,b:=GenerateMatrix(rhs~(dat[1]),lhs~(dat[2]));
Xt:=applyop~(apply,1,dat[2],t);
X:=<lhs~(Xt)>;
v:=diff~(X,t)=A.X-b;
vi:=eval(X,t=dat[3])=<dat[4]>;
sys:=convert(Equate(lhs(v),rhs(v)),set) union convert(Equate(lhs(vi),rhs(vi)),set);
userinfo(2,'procname',print(v,vi));
eval(dsolve(sys,_rest),Xt);
end proc:
uses LinearAlgebra;
t:=op(op~(vars));
X:=<lhs~(Xt)>;
end proc:
Thanks to your instructions I developed this little Procedure. I would like to make it more independent, without the need to load "with (DEtools): with (linearalgebra)." Pending comments.
I hag problem with use LinearAlgebra[GenerateMatrix] in ...
Error, LinearAlgebra:-GenerateMatrix is not a module
restart;
with(DEtools): with(LinearAlgebra):
deq:=diff(u(t),t,t)+0.25*diff(u(t),t)+2*u(t)=3*sin(t):
dat:=convertsys(deq,{u(0)=2,D(u)(0)=-1},u(t), t, x, x_p):
Dsolve:=proc (Deq::list)
local dat,A,b,v,vi,ic,X:
A,b:=GenerateMatrix(rhs~(Deq[1]),lhs~(Deq[2]));
X:=<map2(apply,lhs~(Deq[2]),t)>;
vi:=eval(X,t=Deq[3])=<Deq[4]>;
end proc:
cvrs:=Dsolve(dat):
f:=dsolve(cvrs,numeric,output=Array([0,0.25,0.5,0.75,1])):
g:=dsolve({deq,u(0)=2,D(u)(0)=-1},numeric,output=Array([0,0.25,0.5,0.75,1])):
Proc_ConvertSys.mw
Why am I not receiving email confirmations for subscriptions or answers?
restart;
end proc:
cvrs:=Dsolve(dat):
Proc_ConvertSys.mw
Thank you very much, with little change ... get it searched!!
randomforce2.mw
GRACIAS
randomforce2.mw
GRACIAS
A := Matrix([[10, 3, 2, 13], [5, 35, 11, 6], [8, 4, 7, 12], [24, 14, 18, 20]]);
A*~map(evalhf@isprime, A);
Another example
t:=<[$(1..7)]>:
t*~evalhf~(is~(t<~6));
How do it shorter with command Alias?
Another example
t:=<[$(1..7)]>:
Thanks for the ride.
How to color the inner surface of the graph?
plots[animate](plot3d, [[2*cos(2*Pi*r/(20.0)), 3*sin(2*Pi*r/(20.0)), cos(2*Pi*r/(10.0))*cos(2*Pi*((1/10)*t))], r = 0 .. 20, theta = 0 .. 10], t = 0 .. 20, background = Cameras, shading = zhue)
How I can I achieve the animation shown in the accompanying graph?  my attempt is far!
GRACIAS
GRACIAS
Both commands return values ​​"true / false". And what is sought is to evaluate within the matrix to zero values ​​are not prime.
map(isprime, A)
  [false, true, true, true,]
  [true, false, true, false]
 [false, false, true, false]
 [false, false, false, false]
A(~isprime(A)) = 0
A =      0     3     2    13
           5     0    11     0
           0     0     7     0
           0     0     0     0
map(isprime, A)
A(~isprime(A)) = 0
A =      0     3     2    13
           5     0    11     0
           0     0     7     0
           0     0     0     0
2 3 4 5 6 7 8 Last Page 4 of 13
